Rough idle - 2001 Altima
Old 05-14-2007, 11:58 AM
Umpire727's Avatar
Default Rough idle - 2001 Altima
My Altima is experiencing a rough idle when at stop. The CEL came on about a week ago and the code stated a Cylinder 4 misfire. I've change the spark plugs, fuel filter, and cleaned out the throttle body, combustion chamber and intake manifold.
The car feels like it is going to stall with the RPMs jumping, but at soon as I give it a little gas or turn the AC on high, the RPMs level out.
Any ideas? I would hate to take the car someone and get ripped off if it is something that can be done at home.
Thanks
Old 05-14-2007, 08:03 PM
Default RE: Rough idle - 2001 Altima
My Altima does a similarthing. At a stop, after idling ok for about 30 secondsthe idle turns roughand the rpms drop. The CEl will come on and then go off after a while. Got a code PO300, random multiple misfires and cod PO102, airflow sensor error- low air flow. It's going back to the dealer for repair. When I find out what they fixed I will let you know.
Old 05-15-2007, 07:57 AM
Burnnout's Avatar
Umpire727 ... I would guess Throttle Position Sensor.......pdbrains... I would say Mass Air Flow Sensor.
Old 05-15-2007, 08:57 AM
Umpire727's Avatar
Sounds good! I'm going to see what codes pop up for mine today.
Thanks.
Umpire727's Avatar
Burnnout - Is this an easily fixable problem?
Old 05-15-2007, 08:58 AM
Umpire727's Avatar
  #7
Old 05-18-2007, 02:08 PM
i had the same problem and i just replace the distributor and the wires and the car appreciated it .
  #8
Old 05-21-2007, 08:52 AM
Burnnout's Avatar
Honestly... I would take the car to the dealer and have them diag. it..... could save you money in the long run.
  #9
Old 06-07-2007, 09:41 PM
it could possibly be the intake manifold gasket, check the intake near #4 cylinder see if you hear a vacuum leak in that area or you could possibly see part of the gasket blown out
  #10
Old 06-08-2007, 08:36 PM
i brought my car to the dealer he did like i said on my previous message.
nissan
05-07-2009 07:26 PM
mushaiq@yahoo.com
05-10-2007 01:42 PM
radiator
09-21-2006 08:16 PM
handyandhandsome
05-11-2006 07:28 PM
Quick Reply: Rough idle - 2001 Altima
