Go Back   Nissan Forum - Nissan Enthusiast Forums > Nissan Cars > Nissan Altima
Sign in using an external account
Register Forgot Password?
Search
Reply
Thread Tools Search this Thread
Old 09-25-2006, 08:30 PM
ophuss ophuss is offline
Default 94 altima stalls frequently!! HELP
I have had this problem for about two months now where my '94 Altima will
start-up drive for about 5 miles and the dashlights will come on and the
engine will not run. After coasting to the side of the road I will wait
for usually 4-5 min and it will start up again and drive fine usually for
at least another 20-30 miles before happening again. At times the wait
for the restart has taken more than a hour.
The shop I brought it to believed it was the fuel pump, therefore replaced
ther pump with the fuel filter and checked the fuel lines, however no
luck.
Next they replaced the distributor and distributor cap because of heavy
corrosion. It stalled on the way home from the shop.
Next time, they adjusted the timing belt. Still no change in stalling
frequency or pattern of stalling tendencies.
The most recent diagnosis from Nissan is EVAP drain clogged and water
stains on ECM, need to start with replacing ECM for
$1162. The tech also
noted a valve cover that was leaking badly and soaking the ignition wires
that could be replaced for
$245. And a knock sensorcode in system for
$660.
I have read various forum posts from around the net describing the same
problem to a T with no solution. Please help i'm at my wits end.
Thanks
ophuss
Old 09-06-2009, 10:06 AM
purple dream purple dream is offline
I have a '95 that is doing the exact same thing, no one can figure it out.
What was your fix?
Old 09-06-2009, 08:26 PM
Milkman11 Milkman11 is offline
I would replace the valve cover gasket and replace the spark plugs and wires. Excessive oil on the sparks will make the car shut off. I have a lot of oil on my position 4 spark plug and will replace the plugs and gasket tomorrow. Another thing is you should replace the fuel filter (part is usually like 10 bucks) and PCV valve.
Old 09-15-2009, 04:12 PM
patricia19 patricia19 is offline
Wink Stalling
I have the same problem did you ever find out the fix 9/15/2009
Old 09-17-2009, 03:48 AM
scuodecut. scuodecut. is offline
Il s'agit d'un forum intéressant pour tout le monde
Old 09-21-2009, 10:23 AM
I haven't fixed it, it is just sitting waiting for a solution.
Do you have a solid idea?
  #7
Old 10-04-2009, 07:44 AM
juliarichard34 juliarichard34 is offline
You are spending to much money in replacing the parts,so its better to have a new car in a same.You will get rid out of the tension.
__________________
Nissan Altima 2006 Nissan Performance Chip
Reply
Tags
1995, 93, 94, 94altima, altima, cover, gasket, nissan, pcv, replace, runs, shut, stalling, stalls, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
