siphoning fuel out of gas tank
Old 04-13-2007, 03:32 PM
purple's Avatar
Default siphoning fuel out of gas tank
I got a plastic siphoning kit at the parts store. There's a quarter of a tankful of gas.
The Haynes manual says to remove fuel cap and siphon fuel thru the narrow opening.
The salesperson at the parts store told me to wiggle the clear hose. It's bumping into something.
Called the kit manufacturer and operator told me there is some sort of ball that prevents the hose from going all the way into the tank to prevent fuel from spilling during a rollover. Is this true with the B14 Sentra?
Are there other ways of siphoning the fuel out of the tank?
Thanks.
Old 04-15-2007, 05:06 AM
Default RE: siphoning fuel out of gas tank
you can disconnect the fill up hose that goes into the tank from the fill tube and hook the siphoning kit on there. why do you need all the fuel out?
Old 04-15-2007, 07:48 AM
purple's Avatar
It's got a little of a quarter of a tankful of gas. It's been sitting there almost 3 months. I want to be on the safe side since I will be replacing the fuel filter and the fuel pump.
Can I check the operatyion of the pump by hooking a rubber hose or small metal pipe to the fuel hose at the fuel filter and into the gas container to see if it fills the container after turning key on?
Old 04-16-2007, 12:15 AM
you dont have to remove that gas it should be fine once you fill the rest of the tank with new gas and gas doesnt go bad for about 6 months or so, you should be fine dont even bother with siphoning the gaslol.
paultmak
Nissan Murano
10
07-08-2021 10:47 AM
maggiesmim
05-18-2015 06:52 AM
pachou
11-08-2011 06:03 AM
codybrown
04-03-2008 06:44 PM
kungfoo2003
11-15-2005 11:35 PM
Quick Reply: siphoning fuel out of gas tank
