-   Audio/Visual Electronics (https://nissanforum.com/forum/audio-visual-electronics-26/)
-   -   Vexing problem for bose 350z 6cd (https://nissanforum.com/forum/audio-visual-electronics-26/vexing-problem-bose-350z-6cd-5461/)
handyman8008 Mar 4, 2009 04:02 PM
Hello everyone, ill try and lay this out as best as i can recall. I took my 06 silverstone Z to the nissan dealer to have my bose 6cd changer worked on due to a jammed disc. Only thing the screen reads while on cd is eject, then a number whichever i picked ie..(1,2,3,4....) Well i pull in and park my car like the usual in the garage, J checks out my mileage and i happen to be 300 over warranty for this. :mad:. So with a quick smirk from J i head out knowing it will cost 400+ to fix my bose because apparently they dont fix the bose on the spot but send it away to bose HQ.
So being the hardwired do it myself man that we all try to be i looked it up on the good ol' web. Found out how to remove the dash and all that jazz along with the bose CD box(case). Then i made my frist mistake, without any regard of recording my operations I blatantly removed all the outer 9999 different types of screws from the case, took off the main casing and took a gander at the innards.
This is where im stuck folks, i very much need some advice, links, picutres or some information i can use to at the very least put the right screws back into place.. (pic of the bose 6 cd changer assembled). Also if you would know be able to point me in the way of getting the damn cd's out id love that too.
Thanks for everyone's consideration.
"who says the normal joe can't do what the Man expects us to silently pay for such a service"
ribonzz Jun 4, 2009 06:24 AM
Be calm buddy .. Why don't you take your car to another dealer?
kurtdaniel Jul 9, 2009 04:26 AM
good luck with the solution..havent tried it before..but by the time ive had prob with my cold air intake,,good thing my dealership helped..
full house Nov 3, 2009 08:29 PM
Its a hard problem you got there!you need some advice from experts... go to experts mechanics let them check and advice good solutions to it.
