1995 body swap
RE: 1995 body swap
anything is possible these days, ive never done it but with a bit of fabrication im pretty sure that it can be done, the first step is to measure your wheelbase and make sure both of them are exactly the same, then measure to see where the body to frame mounts are and see if there the same if not your going to have to make your own body mounts and then once you do that then you just have to check clearance everywhere else. but id say go for it and you will learn alot about your truck when you do it.
good luck
good luck
