02 max transmission
02 max SE Auto Trans w/ 4,500 miles...
transmission will shift hard between 1st and 2nd, normal to 3rd...will not shift to 4th replaced fluid w/ Nissan trans. fluid... 6qts. is there a lock up switch of some sort to look at...any adjustments to be made...? my shift lock release is broken, soi don't have to press the brake to move the shifter from P to R to N to D 3-2-1 Can anyone tell me what the Neutral Safety Switch is? |
RE: 02 max transmission
ORIGINAL: parceroreal 02 max SE Auto Trans w/ 4,500 miles... transmission will shift hard between 1st and 2nd, normal to 3rd...will not shift to 4th replaced fluid w/ Nissan trans. fluid... 6qts. is there a lock up switch of some sort to look at...any adjustments to be made...? my shift lock release is broken, so i don't have to press the brake to move the shifter from P to R to N to D 3-2-1 Can anyone tell me what the Neutral Safety Switch is? |
| All times are GMT -5. The time now is 07:50 AM. |
