1989 Stanza, no brake lights
OK.... I NEED HELP....
have a 1989 Stanza that will not light the tail lamps when the brake pedal is pushed.... it IS NOT the switch at the brake pedal. I tested the switch with a meter and it worked fine, I also jumpered the wires that plugged into the switch and did not get any brake lights. I need suggestions..... Thanks, -Tim |
RE: 1989 Stanza, no brake lights
It's probably just the rubber grommet that the pedal uses to contact the brake switch.
