-   -   1992 Sentra Headlight Issues (https://nissanforum.com/forum/general-nissan-tech-9/1992-sentra-headlight-issues-1420/)
tempestdude Mar 1, 2006 03:43 PM
I have a 92 Nissan Sentra E with 233000 miles on it. It runs great and delivers 34-37 mpg.
Within the last several weeks the headlight on the passenger side has been intermittent as far as working on the high & low beem. Sometimes the highbeem will work, sometimes not. Lately the low beem will not work and the highbeem will work. Driver's side is working fine. I replaced the bulb when these issues initally appeared. I read in a similar post of a Pathfinder having a multi-funtion swith under the dash that may cause light issues. Does anyone know if the Sentra has such a switch? I was leaning towards the headlight switch. Any assistance would be greatly appreciated.
Thanks,
Kevin
HXC_Nismo Mar 3, 2006 02:08 AM
RE: 1992 Sentra Headlight Issues
well before you start throwing parts at it i would first check your ground connection cause with that many miles it could of come loose, it should be located on the inner fenderwell by the light that is acting up on you. cause if it was the switch both of your headlights would be acting up on you, well good luck
