1995 SHORTBED PICKUP GEN. MAINTENANCE
Old May 30, 2007 | 12:10 PM
DBGFREEUSA's Avatar
Default 1995 SHORTBED PICKUP GEN. MAINTENANCE
I've owned a '95, 4 cyl. pickup since 1997. It had approl. 15K at the time and now has approx 75K miles. I was rear-ended in this vehicle in the spring of 2001, am still greatly suffering from back and neck disk problems. Our pickup is a 5th vehicle and receives limited but regular use back and forth to Home Depot, etc. I plan on performing as much maintenance on this vehicle myself.
At the current time it is due for an oil change and I believe it needs a brake job. An oil change should not be any problem at all although I would greatly appreciate a step by step guide to go by. The brake job should also not be too complicated, but I may need a specialized tool or two plus a step by step guide. I plan on flushing out the old brake fluid at this time as well. I have not searched this forum for any of this info yet. If any of you can aim me in the right direction, I'd appreciate it.
Thanks, David
neidpath
Oct 20, 2012 11:46 AM
WHITEY
Jan 15, 2009 11:39 PM
sidearm17
Apr 24, 2007 07:16 PM
gps
Jun 24, 2006 04:03 PM
ZTOY
Nissan 300zx
Sep 30, 2005 03:22 PM
