-   -   1997 Maxima (https://nissanforum.com/forum/general-nissan-tech-9/1997-maxima-148/)
Nybill44 May 26, 2005 06:10 PM
1997 Maxima
Sirs I would like some help on a 1997 Maxima I have a check engine light coming on and im getting codes (600) (720) and (443) the speedomotor was disconnected when i bought the car a few years back and connected it right away ... Now I went to get the car inspected and it failed it seems the previous owener had removed the check engine bulb so i never knew there was a problem I would like to know if anyone can help me with these codes since i don't see any relationship to them to each other ....... Also a few months after connecting the speedomotor it stopped working I thank you for your time and appricate any help you can give
My E mail address is Nybill44@aol.com
Thank you very much
William
txq45 May 30, 2005 04:50 PM
RE: 1997 Maxima
I don't have the codes your requesting but you can call the Nissan service shop and get them or for faster answer just search the code with google...
Good Luck
TXQ45
Patrick May 31, 2005 12:49 AM
RE: 1997 Maxima
i agree with txq....any nissan dealership will be able to tell you what the codes mean.
Judas Oct 29, 2005 06:19 AM
RE: 1997 Maxima
According to my Haynes repair manual, here's what the codes mean...
720 - Vehicle Speed sensor or circuit fault
600 - A/T Control Unit or circuit fault
443 - EVAP canister purge control valve circuit fault
I hope this helps. As far as a fix...I would assume, that when you reconnect the speedometer, the codes could be cleared by a place like Advance Auto parts. If not, you are going to have to go to a Nissan service center...but at least you know what the codes are now.
