1998 Heater/ AC ducts and Control
Not getting air flow from ducts at eye level. The air flow from the floor and defroster are working but not when set to the eye level and only from the bottom on the when set to the combo floor setting. The fan is working for all settings. In my Haynes manual you get nothing on this problem. Can anyone help
RE: 1998 Heater/ AC ducts and Control
Hello new member and Welcome into the forums...
I would look into the heater control valve under the hood and also the blend door under the dash.. See if these might get ride of the problem. WheelbrokerAng[sm=americanasmiley.gif] |
| All times are GMT -5. The time now is 08:40 AM. |
