2000 Xterra Air Con problem! Help!!
I have taken my Xterra back to the dealers at least on five occasions because my air con just stops working.
On the last two occasions they said it was the high pressure hose and both times it cost me over $450! The last time I got this repaired was in May 2006, and now as before the Air Con has just stopped working again! Does anyone have any idea what the problem could be? The dealer in Tampa isn't very helpful at all and their lack of help to solve the problem is causing me great concern, I would just like the problem solved once and for all, if anyone has any alternative ideas I would be most greatful. Thanks, Henryp |
RE: 2000 Xterra Air Con problem! Help!!
The highpressure hose going bad is common .... if they replaced it and then the same problem happens again you shouldn't have to pay for it.... if it's a defective part it would be a parts warranty and if it's on something they did wrong installing it, it would be a service warranty.
| All times are GMT -5. The time now is 04:45 AM. |
