2006 Altima belt replacement
Hello,
Anyone know how to replace the accessory belt (P/S) on a 2006 Altima (3.5L)? I can get the clamp bolt loose and the adjustment bolt to move, but I get no slack in the belt to pull it off and replace it. Getting the main drive belt (A/C and Alt.) off is no problem. Help is much appreciated. |
tI think that is not any more a do it yourself thing. 2006 Nissan Altima Serpentine Belt replacement should be taken to the dealer. But if you have tools and guide you might do it on your own. But that is not easy. Edmunds.com or Carguide.com might help you.
just DIY. its an easy stuff..everything is written in the manual. or if it still seems hard, google it and get your problem solved in minutes :)
| All times are GMT -5. The time now is 04:06 AM. |
