When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
2012 Nissan Versa 1.6SV goes into "limp mode" right after starting
Hi, This is my last ditch attempt to fix my car. I have spent almost CAD 3000 at Metro Nissan (official Nissan dealership) Montreal and the problem isn't fixed. My 2012 Nissan Versa 1.6SV goes into "limp mode" right after I start it up. In an attempt to solve this problem Metro Nissan at first changed the throttle body and air filter. When the problem came back after 1 week they changed the IPDM. The IPDM change did not even last a day and the problem came back.
All the replaced parts are OEM.
Does anyone know what the problem is? Can anyone suggest some place in Montreal that can solve this? Otherwise, I might have to scrap the car.
IF accelerator pedal assembly is anything like 350Z....The "spacer" behind the bar inside the assembly deteriorates and
breaks. This causes the pedal to relax past "idle" expected distance. There is no part number, but would have thought the
dealer would be familiar. They will try to sell you the entire assembly OR the "fix" is a 1" nylon bolt and wing nut.
It will be obvious where to install. Should cost you $4 if you have 10mm socket and extension.
