-   -   2012 Nissan Versa 1.6SV goes into "limp mode" right after starting (https://nissanforum.com/forum/general-nissan-tech-9/2012-nissan-versa-1-6sv-goes-into-limp-mode-right-after-starting-41281/)
anis_huq May 14, 2023 10:27 PM
Hi,
This is my last ditch attempt to fix my car. I have spent almost CAD 3000 at Metro Nissan (official Nissan dealership) Montreal and the problem isn't fixed.
My 2012 Nissan Versa 1.6SV goes into "limp mode" right after I start it up. In an attempt to solve this problem Metro Nissan at first changed the throttle body
and air filter. When the problem came back after 1 week they changed the IPDM. The IPDM change did not even last a day and the problem came back.
All the replaced parts are OEM.
Does anyone know what the problem is? Can anyone suggest some place in Montreal that can solve this? Otherwise, I might have to scrap the car.
Bye.
https://cimg0.ibsrv.net/gimg/nissanf...7d8e68008e.jpg
LakeshoreLeo1953 May 15, 2023 06:44 AM
IF accelerator pedal assembly is anything like 350Z....The "spacer" behind the bar inside the assembly deteriorates and
breaks. This causes the pedal to relax past "idle" expected distance. There is no part number, but would have thought the
dealer would be familiar. They will try to sell you the entire assembly OR the "fix" is a 1" nylon bolt and wing nut.
It will be obvious where to install. Should cost you $4 if you have 10mm socket and extension.
