350Z Clutch or Master Cylinder?
2003 350 with following symptoms/problems. Still have pedal press. feels like gears are engaging from shifter with pedal up or down but no engagement at all. Acts as if clutch is fully engaged full time. ZIf clutch is out, I've never experienced one going out like this. Any ideas at all would be appreciated....
So sorry but your clutch has gone out. If it was with following symptoms you could start in gear and drive but with the clutch worn out there would no movement of the auto.At all in most tme or the pressure plate has broken. in both problems the clutch is replaced with a new pressure plat and clutch and throw out bearing.
ORIGINAL: BadAndy66
michaeltroy
Feb 19, 2015 08:35 AM
michaeltroy
Feb 13, 2015 09:12 AM
michaeltroy
Feb 3, 2015 09:04 AM
michaeltroy
Dec 25, 2014 05:08 AM
