-   -   350Z Clutch or Master Cylinder? (https://nissanforum.com/forum/general-nissan-tech-9/350z-clutch-master-cylinder-2821/)
BadAndy66 Nov 19, 2006 12:01 AM
2003 350 with following symptoms/problems. Still have pedal press. feels like gears are engaging from shifter with pedal up or down but no engagement at all. Acts as if clutch is fully engaged full time. ZIf clutch is out, I've never experienced one going out like this. Any ideas at all would be appreciated....
n6rrj Nov 19, 2006 12:43 AM
RE: 350Z Clutch or Master Cylinder?
So sorry but your clutch has gone out. If it was with following symptoms you could start in gear and drive but with the clutch worn out there would no movement of the auto.At all in most tme or the pressure plate has broken. in both problems the clutch is replaced with a new pressure plat and clutch and throw out bearing.
BadAndy66 Nov 19, 2006 12:47 AM
Was afraid that was the case..Anybody know where to get a clutch halfway cheap?
Fraggle2005 Dec 15, 2006 09:51 PM
ORIGINAL: BadAndy66
PM sent
Fraggle2005 Dec 15, 2006 09:53 PM
ORIGINAL: BadAndy66
Also If it only a couple, poss synchro, 3rd gear goes often
