| DEVO |
Jan 3, 2006 07:20 PM |
RE: 93 Altima bad moto mount
You shouldn't have to remove the engine to replace the mount. Is it the front or rear cradle mount? If it is one of those you should be able to support the engine from underneath. (Think a floor jack and blocks.) Loosen up the cradle that runs from the front to rear of the engine bay. If you cant get it out then take the cradle off completely. Its a common problem w/older altimas and maximas. A skilled tech can do it in 30 min to 1 hour. Average do it yourselfer 1-2hrs. Good luck.
