Air con problem in Nissan Primera - help please
Old Sep 11, 2005 | 11:47 AM
rodb's Avatar
Default Air con problem in Nissan Primera - help please
I'm not much of a techie, so apologies if this is a silly question! The air con has stopped working, it's not the fuse, so is there anything else I can do / check out before I admit defeat and call in the professionals? Any ideas / help much appreciated!
Old Sep 23, 2005 | 10:18 PM
Default RE: Air con problem in Nissan Primera - help please
did you check the wire at the ac compressor to see if it is connected and check your ac switch in the car to see if it has corrosion but if you are not much of a mechanic i would recomend you bring it to the nissan dealer cause you can actually make it worse, no offense.
pedrom
Jul 1, 2010 05:26 AM
rlk001
Nissan Skyline
Apr 21, 2008 12:57 AM
soundssupreme
Jan 22, 2008 09:50 AM
jeannette1
Mar 7, 2007 06:42 PM
henyp
Dec 1, 2006 12:47 PM
