brake lights
I have a 99 Maxima. All rear lights work except the brake lights. None of the brake lights work when the pedal is pressed. I have checked the bulbs and they seem fine. Does anyone have a solution about what I should check?
Another probable cause could be loose sockets,In my case my nissan lights specifically the tail lights always suffer from that. cause I think a have a leak from somewhere causing my sockets to get coroded therefor loosing connection
+1 .... it's either gonna be the brake switch or the little rubber piece on the back of the pedal that hits the brake switch.
