-   -   brake lights (https://nissanforum.com/forum/general-nissan-tech-9/brake-lights-2965/)
sangel Dec 13, 2006 08:19 PM
brake lights
I have a 99 Maxima. All rear lights work except the brake lights. None of the brake lights work when the pedal is pressed. I have checked the bulbs and they seem fine. Does anyone have a solution about what I should check?
Fraggle2005 Dec 13, 2006 08:29 PM
RE: brake lights
Brake switch? did you check for power and ground at the sockets?
Burnnout Dec 14, 2006 11:24 AM
RE: brake lights
:eek:+1 .... it's either gonna be the brake switch or the little rubber piece on the back of the pedal that hits the brake switch.
Fraggle2005 Dec 15, 2006 09:48 PM
RE: brake lights
ORIGINAL: Burnnout
Did not think of that. +1
justin_p May 17, 2007 02:03 AM
RE: brake lights
Another probable cause could be loose sockets,In my case my nissan lights specifically the tail lights always suffer from that. cause I think a have a leak from somewhere causing my sockets to get coroded therefor loosing connection
