A/C Drain
My 1996 Nissan pickup is leaking water into the passenger side floor. The water is coming from a clogged A/C condensation drain. Anybody know how to fix this properly. I took it by a shop and they blew air through the drain. That worked for one day. How do I access the drain pan and clean it out?
Thanks |
RE: A/C Drain
VERY common problem the drain is merely going to be a hose under the car in the general area of the blower motor assy. box. the blowing air trick usually does it for good unless you have a lot of crap in there follow it up the hose to see if you can access its point of origin and you will probably find the dirt. if not then keep on blowin it out and eventually you will be good.
RE: A/C Drain
oh i forgot to mention to access the pan just look at the box under the dash, should be held in place by several small screws or torx bit bolts, the bottom comes off to access the heater core and blower motor assy.
