-   -   Can someone Recommend a mechanic in Richmond? (https://nissanforum.com/forum/general-nissan-tech-9/can-someone-recommend-mechanic-richmond-4144/)
melanneva Sep 4, 2007 07:52 PM
Hi, can someone recommend a good mechanic in Richmond, VA? I have a 1999 Nissan Maxima...
Thanks!
Burnnout Sep 5, 2007 08:54 AM
RE: Can someone Recommend a mechanic in Richmond?
Hmmm .... not in Richmond but I could recommend many in the hampton roads area ...... what seems to be the problem with your Maxima ?
melanneva Sep 5, 2007 07:45 PM
I'm losing clutch fluid and my clutch pedal is all the way down to the floor... do you know where the bleeder valve is located? My roommate is mechanically inclined and he said if it is similar to bleeding brakes, he could probably do it... I have a 1999 Nissan Maxima....Thanks!
