Check Engine Light on!>> 97 Maxima SE
I had the computer scanned and it came back with some info
PO 105
MAP/BARO
Sensor Circuit Problem
What does this mean and how do I fix it? Anyone with INFO that would be great!
Thanks
E
RE: Check Engine Light on!>> 97 Maxima SE
Call a Nissan service dept. Most that are good will tell you what the code involves. The map /baro sensor is also the "boost" sensor. If I remember correctly, it is part of the evap system back near the fuel tank and carbon canister or its under the hood and its part of the vaccuum system. Either way call your local Nissan parts dept and ask for the boost sensor. They can give you price and availability and even a picture of it and where its located. Provided the parts dept has FAST or other computer film software.
