clutch on 1990 TT 300zx
I have been trying to fix my problem, please help if you can!
I was driving when I noticed that I could not get the car in gear. There is a nut located on the push rod just above the clutch pedal that was loose. I thightend it and it worked for about 2 weeks. At that time when I just made it home the push rod had come all the way loose. I agin thightened it but to not avail I still could not shift. I have replaced the master cylinder as well as the slave unit. Blead both bleeder lines to where fluid was running through them. At that time it was up on jacks and worked fine. I take it down start it up and again can't shift? When under car I noticed the withdrawer lever was thight up against the slave cylinder rod? Is the normal? All vacum hoses are fine no leakes. Thanks for any info to help me would be appericated I miss driving my car. |
| All times are GMT -5. The time now is 09:45 AM. |
