dash guages
My 1988 Pulsar dash guages do not work most of the time. Only the gas guage works periodically. How do i go about fixingthis problem?
RE: dash guages
do all the other dash lights (ie speedometer) work?
RE: dash guages
Yes the speedometer works, it's the tach, and oil pressure guages that don't.
RE: dash guages
OK...that is good that the speedometer has lights as this is an important gauge. I'm not familiar with your car interior. So is the tach bundled with the oil pressure other gauges or is a separate instrument like the speedometer?
RE: dash guages
Ok, the guages are, tach on the left, speedometer on the right, the temp guage on the top in the middle, and the gas guage in the middle bottom. The speedometer is theonly guage that works. The gas guage only works periodically, and then almost always reads 1/4 tank.
RE: dash guages
speedometer is working as this has a direct mechanical connection to the transmission via a rotating cable. The other gauges most likley transmit a small electrical signal from a transmitter (such as a pressure transmitter for oil pressure) to the gauge. As such, I would check the fusible links to make sure that none have a burned out wire; you owner's manual should show you were they are located and which provide protection from overcurent to each dash guage.
