Fan motor switch
Intermittent operation of fan for heating and ac/ operated when cooler outside in AM but not when the weather warms up, now wont come on at all, any suggestions. Schematic info, or switches?
RE: Fan motor switch
Hello New Member...WheelBrokerAng here....
This could be a blower fan motor relay switch-that you can buy at your local AutoZone or NAPA parts store...Let me know if that works out for you! And again [sm=welcomesign.gif] to the forums... WheelBrokerAng[sm=americanasmiley.gif] |
PULL THE BLOWER MOTTER CHECK THE BRUSHES ON THE INSIDE.
MY 93 NX DID THE SAME THING THE BRUSHES WERE BURD OUT, OR IT MY NEED CLEAND.. |
I needed a new blower switch installed because the fan only worked on high speed...the part was $40.
I had the same problem.....switch only worked on high. Replaced the switch and still would only work on high after spending $45. I guess the relay is next.
