fan only blows on high
Hi: hoping someone here can help me figure out why when i put the a/c on in my sentra it will only blow if it is on the highest fan setting :: if i lower the fan speed the a/c stays on but barely any air comes out of the vents.
thanks in advance for any help. Carole |
RE: fan only blows on high
Hi...I had this problem on one of my past vehicles and found out that it was the blower switch itself that was not making a complete contact on itself..
Chek with you dealer and see if this answer might be on focus. WheelbrokerAng[sm=americanasmiley.gif] |
it was the blower switch itself |
Hi Carol. That exact situation happened to my 94 Altima. I took it to the mechanice and he replaced the 'switch' I'm sorry I don't know the correct terminology but the part was $40. He installed it and it works on all speeds...
My Pathfinder has the same problem. Replaced the switch and still only works on high. I've bben told there is a resistor pack near the blower motor but I can't find it. Anybody know where it might be on a 03 Pathfinder?
your blower motor is under the passenger side of the dash and the resistor should be in that area it almost looks like a relay, you might have to take off the glove box to to gain access to the resistor.
| All times are GMT -5. The time now is 02:31 AM. |
