gauge problem
I just purchased a 1998 nissan frontier. the dash gauges donot work. the temp and fuel gauge read max at all times and the speedo and tach only read a few mph and rpm. does anyone have a solution.:):)
Check the fuses first, then you may have to look for loose connection on the dash circuit board.
It may possibly be a bad circuit causing the whole board to short out. |
gauges
thanks i'll ck it out
| All times are GMT -5. The time now is 01:05 AM. |
