headlight
im driving a 1992 nissan nx (pretty much a sentra) and the left front headlight doesnt work. the buld is fine, all the wires look good and its getting really frusterating. anyone have any ideas?
RE: headlight
check for voltage if no voltage check your fuses and check the ground wich is under the headlight and make sure its clean. also if you can check the bulb with an ohm meter and make sure its not blown cause ive seen bulbs that dont look blown but are. have you already replaced the bulb? and remember do not touch headlight bulbs glass with your hands cause the grease of your skin will cause the bulb to blow.
| All times are GMT -5. The time now is 02:30 AM. |
