-   -   Help with 1997 Hardbody pickup (https://nissanforum.com/forum/general-nissan-tech-9/help-1997-hardbody-pickup-5254/)
ajd Nov 15, 2008 09:15 AM
I need a little help trying to figure out why my truck is having trouble starting up. I recently had the following work done...
-tune up... ie. new wires, plugs, fuel filter, cap, pcv valve.
I figured the truck would start up better after the tune up but it did not. So i hooked up my obd2 scanner and found that the throttle position sensor was not working correctly. I replaced it and it still starts up rough. By rough i mean i have to crank it once, stop, then on the second crank it usually turns over. If the truck is cold it is worse. If it is after a warm start it usually fires up.
So, taking my mechanics advise which was a bad fuel pump, I dropped the tank and replaced the pump. Still starts up rough. I replaced the fuel pump relay switch. That also did not work.
I am really at a loss as to why it is not starting up correctly. The truck has just under 80k miles. Someone said maybe a bad crankshaft position sensor... I don't know. It has the 4 cylinder 240sx engine in it i believe... the stock one.
Any help would be greatly appreciated.
thanks[:@]
