how do i remove the pathfinder door panel?
Old Feb 28, 2006 | 02:01 AM
seadoohx's Avatar
Default how do i remove the pathfinder door panel?
1996 pathfinder le i want to check my speakers and how do i remove the panel? is it all snaps or are there screws as well?
is there any quick link to a manual on the web that i can look at.. thanks in advance
lhrncir@aol.com
Old Mar 3, 2006 | 02:00 AM
Default RE: how do i remove the pathfinder door panel?
you should have one screw on the inner door handle, two on the front part of the door panel by the hinges, couple on the bottom and one inside the handle you pull to close the door and then there are clips left holding the door it should just pop of just be careful and double check for any other screws.
LittleHaiti203
Jun 14, 2007 02:50 AM
caputomail
May 1, 2007 12:41 PM
C.D.
Mar 9, 2007 07:34 PM
osgood
Jun 16, 2006 10:48 PM
osgood
May 2, 2006 08:59 AM
