Nissan Fault Codes List
Nissan DTC
P1105 MAP/BARO Pressure Switch Solenoid Valve P1110 Intake Valve Timing Control Solenoid P1120 Secondary Throttle Position Sensor Circuit Fault P1125 Tandem Throttle Position Sensor Circuit Fault P1126 Thermostat Function P1130 Swirl Control Valve Control Solenoid Valve P1135 Intake Valve Timing Control Circuit (Bank 2) P1140 Intake Valve Timing Control Position Sensor (Bank 1) P1145 Intake Valve Timing Control Position Sensor (Bank 2) P1148 Closed Loop Control (Bank 1) P1165 Swirl Control Valve Control Vacuum Switch P1168 Closed Loop Control (Bank 2) P1210 Traction Control System Signal Fault P1211 ABS/TCS Control Unit P1212 ABS/TCS Communication Line P1217 Engine Over Temperature (Overheat) P1220 Fuel Pump Control Signal Fault P1320 Ignition Signal P1335 Crankshaft Position Sensor (REF) P1336 Crankshaft Position Sensor (CKPS) P1400 EGRC Solenoid Valve P1401 EGR Temperature Sensor P1402 EGR System P1440 EVAP Control System Small Leak P1441 Vacuum Cut Valve Bypass Valve P1443 EVAP Canister Control Vacuum Switch Circuit Fault P1444 Canister Purge Volume Control Solenoid Valve P1445 EVAP Canister Purge Volume Control Valve P1446 EVAP Canister Vent Control Valve (Closed) P1447 EVAP Control System Purge Flow Monitoring P1448 EVAP Canister Vent Control Valve (Open) P1464 Fuel Level Sensor Circuit (Ground Signal) P1490 Vacuum Cut Valve Bypass Valve (Circuit) P1491 Vacuum Cut Valve Bypass Valve P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit) P1493 EVAP Canister Purge Control Valve/Solenoid Valve P1550 TCC Solenoid Valve P1605 A/T Diagnostic Communication Line P1701 Fuel Trim P1705 Throttle Position Sensor Circuit A/T P1706 Park/Neutral Position (PNP) Switch P1760 Overrun Clutch Solenoid Valve (Circuit) FULL DTC LIST YOU GET HERE |
