Nissan serena 1.6, pls help!
Hi all,
I have a N reg nissan serena 1.6 lxI know it has the GA16DE engine so here what I need help with...
1, Can I use a clutch off any GA16DE engine for my serena? I know these cars had the same engine...
Almera, Primera, Sentra, Sunny, and the 100NX....
2, What would I need to do to change the rear suspension on my 1.6 for the rear suspension off a 2.0 serena...
3, I have a strange overheating problem... it starts to overheat but if I floor it a cupple of time the block clear's, I start to gethot air from the heater and the temp falls, I have bleed the system more time then I can remember.. so I dont think I have a air lock.. any idears...
Thanks for any help...
the overheat problem could be your thermostat, might not be opening all the way at lower temps and then flooring it to raise the temp causes it to open. i had a problem like that on my old car
clutch should be fine but check with a reputable parts supplier for conformation
I have a 93 serena with the 2 litre motor and a 5speed manual. i want to know if i can bolt on a turbo and what is the best size one for it
beazo40
Oct 27, 2009 02:17 AM
blackmaxi717
Mar 14, 2006 10:51 PM
