-   -   Nissan serena 1.6, pls help! (https://nissanforum.com/forum/general-nissan-tech-9/nissan-serena-1-6-pls-help-3116/)
DRAVEN Jan 18, 2007 08:41 PM
Hi all,
I have a N reg nissan serena 1.6 lxI know it has the GA16DE engine so here what I need help with...
1, Can I use a clutch off any GA16DE engine for my serena? I know these cars had the same engine...
Almera, Primera, Sentra, Sunny, and the 100NX....
2, What would I need to do to change the rear suspension on my 1.6 for the rear suspension off a 2.0 serena...
3, I have a strange overheating problem... it starts to overheat but if I floor it a cupple of time the block clear's, I start to gethot air from the heater and the temp falls, I have bleed the system more time then I can remember.. so I dont think I have a air lock.. any idears...
Thanks for any help...
DRAVEN Jan 25, 2007 09:36 AM
RE: Nissan serena 1.6, pls help!
ANYONE????
pryde300zx Jan 25, 2007 01:50 PM
the overheat problem could be your thermostat, might not be opening all the way at lower temps and then flooring it to raise the temp causes it to open. i had a problem like that on my old car
DRAVEN Jan 25, 2007 06:00 PM
Thank's for the info mate I'll try it and see..
shadowrunner Feb 10, 2007 10:19 AM
clutch should be fine but check with a reputable parts supplier for conformation
I have a 93 serena with the 2 litre motor and a 5speed manual. i want to know if i can bolt on a turbo and what is the best size one for it
Burnnout Feb 10, 2007 11:20 AM
Yes you can.... what kind of power are you looking to get out of your car ?
shadowrunner Feb 14, 2007 07:47 AM
well it already beats turbo'd WRX's to 100kph but i want more topend power for towing mainly, and bolt on power is the easiest and fastest way to get it. it has already been blueprinted and ported
