NO STATION MEMORY
HI, I AM A NEW MEMBER AND JUST RECENTLY FITTED A NEW STEREO TO MY MICRA. THE ONLY TROUBLE I HAVE IS THAT WHEN THE IGNITION IS TURNED OFF I LOSE THE STATION MEMORY AND HAVE TO RETUNE EVERYDAY. I HAVE CHECKED THE ISO ADAPTOR AND THE NISSAN LEAD CONNECTORS AND THEY SEEM TO FIT WELL. ANY IDEAS?
micra 1.3 LX L plate
CHEERS RICH
CHEERS RICH
it sounds like something is either bad in the radio itself which isnt allowing it to store the presets, or something during the installation is incorrect and when the key is off, it is cutting ALL power to the radio which is like when you disconnect the battery.
there is a power wire specifically for memory on your stereo (it needs constant 12volt power). if it is not connected properly, it will go off with the ignition and cause you to loose your pre-sets and clock.
cruisinsti
May 24, 2007 04:10 PM
robinlox
Useless Posts
Sep 1, 2006 04:35 AM
