Oil Cooler Leak
I own a 2001 4x4 SE Pathfinder with a oil leak coming from the oil cooler located underneath the passenger side of the vehicle. Can anyone offer any suggestions on how to fix this problem? Do I have to repalce the entire unit or can I replace seals that may have worn. The vehicle has 77,000 miles and has towed significantly. How do I remove the oil cooler if it does need to be replaced?
Thanks Rocco |
