Pathfinder warning light issue
Hi all,
I have a 2001 pathfinder, 3.5l engine. While driving the other day, the A/T temperature light, the Brake light and the battery warning light all came on at the same time. The car runs fine. Turning engine off then on did not fix the problem. I disconnected the battery for about twn minutes to see if things would reset - no luck. Aany ideas? |
Google "1990 Nissan Pathfiner" and "user manual" and you might be able to download a PDF of that. You could also go to Autozone or Pep Boys or whatever is in your town and buy a Chilton's Guide for your make/model/year.
| All times are GMT -5. The time now is 12:15 AM. |
