Re- Shortshifter for 98nissan200sxse
Hi everybody,
I have 1998Nissan 200sxse 1.6L . I want to know have anybody used ShortShifter in '98 200sx with 1.6L ? I want to install shortshifter in 200sx, but there are some cheap and some expensive shortshifter on e-bay so what would be the difference in both ? and which should i install ? plz help me out of this confussion. and is it good or bad to install shortshifter in my '98 200sxse ? i would really appricate ur all help. and if anybody can suggest which shortshifter should i use and where should i buy.
thanks in advance
nismo
thanks in advance
nismo
well i have a b&m short throw shifter but i dont like it cause the its solid mounted to the shifter rod and it rattles like hell, i would recommend the fidanza cause it would not rattle like the b&m one does and you just reuse your original shifter mount. and also if i were you go ahead and the pay the extra $5-10 dollars for the energy suspension shifter bushings cause they showed me an improvement in shift feel and quality on my sentra. well good luck on your decision.
Thanks man,
But did u know the website from which i can buy the findaza shortshifter and anothe question is that if i use that one does its decreses size of **** rod beacause my main concern is to get short in size shifter , bz its 1.6L car so i dont need short shifting i need is the reduced size of shifter so any response on this . if u can plz do let me know i would appricaite that.
thanks again for ur reply
nismo
nismo
well my b&m was bit shorter from the stock but i could get the shifter for you just email me and we can set somthin up, hxc_nismo@yahoo.com
