Rear caliper
In trying to retract the piston on the rear caliper of my '96 Maxima to allow for the new brake pads, it won't go in. I bought the special tool, which is a big help, but the piston just turns and turns and doesn't retract. The rubber accordian-like gasket is a little chewed up around the piston, could this be the problem. I'm dreading taking the caliper apart. . . . Any suggestions?
Thanks |
RE: Rear caliper
your piston may need to be turned in. if it does not retract in one direction, try it in the other direction. also be sure the e-brake adjustment is not causing the broblem.
| All times are GMT -5. The time now is 07:04 AM. |
