s13 headlights
Does anyone know how to disconnect the headlights on an s13 so they cannot go up or down? I want to set them just once manually to look sleepy.
RE: s13 headlights
Hook it up directly to a switch allowing you to manually turn them on and off.
RE: s13 headlights
heres the write up https://nissanforum.com/m_10190/tm.htm
RE: s13 headlights
simple answer.... at the motors disconect the harness then on the top of the motors there is a black cap...pull it off...red knob underneath maually raises and lowers the lights turn it to desired spot ....wa la! dont forget to secure the harnesses with wire ties so the dont flap around and rattle.. god luck:D
