sensor problem?
97 Nissan truck, 2.4L, 4X4, 134,000 miles. About a month ago, i put some sea foam into a vaccum hose hoping to clean out some carbon and possibly improve MPG. A few days after this my check engine light came on. I assumed maybe a O2 sensor or something. Kept driving with light on. A few weeks later, I was on the highway in 5th and it felt like I lost power. I stopped, tried to take off and it chugged along like I was taking off in 2nd. I stopped, pressed on the gas in neutral and the throttle just reved up and down with the pedal all the way to the floor(acted like i was pushing up and down on the pedal when the pedal was fully engaged). Shut the engine off took the battery cable off to reset computer. this cured the check engine light and temporarily the throttle problem. Anyway, it's a few weeks later and occasionally it will act up. Called a Nissan dealer, answer, Mass air flow ($427, ouch!!). Does this sound like the problem?
dtc? pulled the code for the check engine light=intake air temp sensor. I don't think that is theproblem though. runs fine at an idle it revs up and down when you step on the gas. My dad was conversing on the net about the problem and some guy replied that it sounded like a loose battery cable. I do have a loose (neg) battery cable. Could this be the problem? It sounded strange to me that a loose cable could cause this.
ORIGINAL: 97truck
dtc? pulled the code for the check engine light=intake air temp sensor. I don't think that is the problem though. runs fine at an idle it revs up and down when you step on the gas. My dad was conversing on the net about the problem and some guy replied that it sounded like a loose battery cable. I do have a loose (neg) battery cable. Could this be the problem? It sounded strange to me that a loose cable could cause this.
lovinmyride69
Aug 5, 2020 03:26 PM
