-   -   SENTRA 89 A/C PROBLEM (https://nissanforum.com/forum/general-nissan-tech-9/sentra-89-c-problem-1146/)
BLKSTR Jan 4, 2006 08:59 PM
When I turn my a/c, heater on looks like it works because it lit the blue a/c light inside but doesnt throw any air through the vents. The a/c radiator fan also turns on. What this can be??
HXC_Nismo Jan 8, 2006 04:59 AM
RE: SENTRA 89 A/C PROBLEM
check to see if your getting voltage to your blower motor located under the dash on the passenger side if you are see if you have a good ground and if both of those are good then your blower motor is probably no good.
