| HXC_Nismo |
Feb 27, 2006 08:29 PM |
RE: serena 1.6 coolant system
the best way to get air pockets out of your cooling system is to get a raidiator funnel were it mounts onto a special raidiator cap you can get them off of tool trucks or maybe at part stores there only $12 from matco tools. and your going to have to drain the radiator again and then fill it up with the engine off and fill it up and the funnel and then let the car idle with the heater on and let it idle for about 30minutes and it should get the air pockets out. or you possible have a blown head gasket wich could cause air pockets but you would have white smoke coming out of the exhaust. well i hope this help you good luck.
