Serena Van Cooling Fans
Hi all
I have a UK SpecSerena Diesel van and the cooling fans on the radiator are running all the time the ignition is on I have a manual which shows the Radiator having a Thermo switch to control the fans but the position on the rad is blanked off and has never had a switch, but according to the last owner the fans used to switch on and off dependent on engine temp, any ideas Thanks |
RE: Serena Van Cooling Fans
The coolant temp switch may be located in the thermostat housing..... it's a screw in sensor normally.
