Stuck front rotor
I am trying to take off my front brake rotors, and my left (driver side) rotor comes off fine, however my right side appears to be stuck or secured on there somehow. I completely removed the brake caliper, and even tapped it a few times with a hammer, and still no luck. Any help would be welcome. Thanx. TH
The techs in the shop usually hit opposite sides of the rotor where it mounts on the hub. Make sure that you arent hitting the rotor suface. A good help is to spray the hub/rotor mounting point w/ a good penetrant. Usually one good whack at the 9 and 3 o'clock position is all thats needed. Good luck.
michaeltroy
Apr 2, 2015 08:23 AM
