-   -   Stuck front rotor (https://nissanforum.com/forum/general-nissan-tech-9/stuck-front-rotor-1136/)
tjhanes Jan 3, 2006 05:25 PM
Stuck front rotor
I am trying to take off my front brake rotors, and my left (driver side) rotor comes off fine, however my right side appears to be stuck or secured on there somehow. I completely removed the brake caliper, and even tapped it a few times with a hammer, and still no luck. Any help would be welcome. Thanx. TH
DEVO Jan 3, 2006 07:11 PM
RE: Stuck front rotor
The techs in the shop usually hit opposite sides of the rotor where it mounts on the hub. Make sure that you arent hitting the rotor suface. A good help is to spray the hub/rotor mounting point w/ a good penetrant. Usually one good whack at the 9 and 3 o'clock position is all thats needed. Good luck.
