transmission flush *need advice/info*
hi, i am in the process of doing a transmission flush on my car it has 85k mi. and i wanted to know when is it recommended to do it at, mileage wise? and also how to do it because i want to do a complete flush and i know if i just drain it i will only get a portion of th fluid so how do i go about doing a complete flush, as far as getting all of the fluid in te converter and trans. cooler.
so if any one has a link to a site with instructions, that would really help me out. by the way i have a 2005 sentra 1.8L |
RE: transmission flush *need advice/info*
You need to take it to a transmission shop with a tranny flush machine..... doing yourself is not a good idea. Recommended at 60k. You can do a drain and refill... but the flush needs to be done with a machine.
I do agree with burnout about taking it to a shop with the proper equipment. It is recommendedevery 30k not 60.
30K... You're right.
