Turn indicator lights
Old Nov 14, 2005 | 07:19 AM
dobhranach's Avatar
Default Turn indicator lights
The fuse has blown on the turn indicator lights on my Nissan Serena. When I replace the fuse, it works for a wee while before it blows again. I've looked at all the lights and none of the bulbs are blown. I've cleaned them and made sure the connections are dry. I'm hopeless at electrics. Does anybody know what to check next?
Old Nov 15, 2005 | 03:27 AM
Brad Starkey's Avatar
Default RE: Turn indicator lights
Well, if your fuse is blowing but not right away you must have an intermittent short somewhere. Did anything happened/been done to the car that might have started this happening? Accident; stereo installation; etc? If so, look there for wiring problems.
Things to check: Look for any loose/frayed wires under the dash and around the turn signal switch, lights, etc. Check any wiring jobs you know of. (note: If the car has an add on stereo or anything else electrical, look there real close. Check for any loose connections, frayed wires, etc. If you can't find anything wrong with the wiring anywhere we may have to assume your turn signal switch has gone bad and you'll need to check that out.
Hope that helps,
Brad
brianandchar
Nissan Quest
Oct 12, 2007 07:22 PM
edward1681
Sep 24, 2007 03:06 PM
ORAZION
Apr 16, 2006 12:44 AM
gtrplayr1976
Apr 11, 2006 05:51 PM
pinkslipper32
Jul 6, 2005 02:13 AM
