wiring harness?
Im doing a 1.6-2.0 swap in my 97' 200sx. The motor is from a 92 sentra. Which ecu and wiring harness do i need? Any help would be great thanks
RE: wiring harness?
you would very likely need the proper harness for that engine, as well as the ECU
RE: wiring harness?
you would ne the 2.0 wire harness and ecu for the 2.0 sentra. i am curently doing a sr20det swap in a 91 nissan senta i have everything in my harness will not work with the motor. get the ecu and harness ,it will save you time and a headache
